    Jun 2007
    Ruba 'el Khali
    30
    R410A For -10C Evaporating Temp
    I was going through Sanyo DC Scroll compressor and it is rated for -15 to 12 C evaporator temperature using R410A. So I was thinking if I could build a system around it for making ice as a thermal storage and need evaporator temp of -10C.
    Auckland
    74
    3,357
    37
    Re: R410A For -10C Evaporating Temp
    Good on you , your point being?
    you may need to use a HX as a glycol cooler at -10'c SST at compressor, and possibly get sub zero glycol temps, dependant on compressor performance etc.. and compression ratios, ambient temps etc..
    A little more info would help.
    Jun 2007
    Ruba 'el Khali
    30
    Would prefer to avoid glycol in the primary look rather freeze the tank directly with DX evaporator..
    Auckland
    74
    3,357
    37
    Hi Boss.
    you obviously want to build an ice bank for thermal storage. You would be best advised to select a low temp scroll designed for the purpose
    Earlier I asked for more information on what you wanted to acheive, can you elaborate ?.
    are we talking a few kilowatts or meggar watt ice banks.
