Thread: Fan Coil Unit
    Mar 2016
    Mauritius
    1
    Fan Coil Unit
    Hello,
    I adjusted the chilled water flow rate on several 18,000 Btu FCUs to work as 12,000 Btu units. My question is will it affect the supply air temperature of my fan coil. Also I would like to know whether the blower fan speed (Low, Medium, High) has an effect on supply air temperature?
    Jun 2001
    Chicago Il
    52
    98
    23
    Re: Fan Coil Unit
    ill bite, how did you adjust your flow for 12000 btu?
    Split Croatia
    57
    6,151
    36
    Re: Fan Coil Unit
    On both questions answer is yes!
    Supply air temperature (in cooing) will bi higher (or lower in heating). Reducing fan speed will make it back to normal! Fan speed also affect SHR of fan coil!
Tags for this Thread
