Results 1 to 8 of 8
Thread: R1134a refrigerant pump
11-03-2016, 08:35 AM #1
I got a nice contract to fill once a month 10 bottles of 60kg each from a ton container.
Looking for a dedicated pump for the job.
Anyone who knows something, heard something or seen something that can help, your input is valuable [my bank manager is with me on this one...]
11-03-2016, 04:32 PM #2
Re: R1134a refrigerant pump
Something like this?
http://www.polarpumps.co.uk/e22l-liquid-pump/Mostly found in Oxfordshire, UK :)
11-03-2016, 05:35 PM #3
Thanks,
Sent them a request.
12-03-2016, 10:28 AM #4
If it is liquid would an appion or similar recovery unit work, would the virgin gas kill it i wonder?
12-03-2016, 10:39 AM #5
12-03-2016, 02:18 PM #6
Can you push - pull with your recovery?
Are you putting 10 x 60kg into the ton pig or are you
taking the 10 x 60kg from the pig/
Rob
12-03-2016, 02:21 PM #7
Just re-read your original post, "from the 1 ton pig"
Could you not build a 10 way manifold from pipe and then
vac out the cylinders, plus freeze the cylinders and use the
pressure difference to move the refrigerant?
Rob
12-03-2016, 04:13 PM #8
