01-03-2016, 04:31 AM #1
Condensation on glass door showcase
How to control condensation on glass door show case?
01-03-2016, 04:26 PM #2
Re: Condensation on glass door showcase
Check the seals and keep the doors closed.
01-03-2016, 10:53 PM #3
Check temperature control and if defrost checks drains parameters etc,also what temperature products are being loaded at.
02-03-2016, 01:39 AM #4
07-06-2016, 03:34 PM #5
Hello every body..long time no see..
i want ask about dew test..i have 2 test condition :
1. Ambient temp 25 & RH 90%
2. Ambient temp 32 & RH 90%
which one will make condensation happened faster ??
07-06-2016, 04:37 PM #6
If I understand the question correctly, that would be #2. It contains more moisture and condensation would occur at a higher temperature (higher dewpoint).
