    Mar 2011
    Tangerang
    31
    8
    Condensation on glass door showcase
    How to control condensation on glass door show case?
    70
    10,627
    52
    Re: Condensation on glass door showcase
    Check the seals and keep the doors closed.
    Feb 2009
    telford
    2,068
    27
    Check temperature control and if defrost checks drains parameters etc,also what temperature products are being loaded at.
    Nov 2010
    wales
    9
    Quote Originally Posted by cadwaladr View Post
    Freezer glass doors usually have heaters fitted, check if you have electric cable into door. If you have, check power supply, voltage usually on a label on the door frame, could be a fuse blown?
    Mar 2011
    Tangerang
    31
    8
    Hello every body..long time no see..
    i want ask about dew test..i have 2 test condition :
    1. Ambient temp 25 & RH 90%
    2. Ambient temp 32 & RH 90%
    which one will make condensation happened faster ??
    Apr 2001
    73
    5,069
    29
    If I understand the question correctly, that would be #2. It contains more moisture and condensation would occur at a higher temperature (higher dewpoint).
