    Feb 2016
    jamaica
    1
    Daikin Super Inverter
    I just install a new pc board to this condensing unit and it just wont work error code is UA can someone assist
    3,856
    Re: Daikin Super Inverter
    https://www.climatecenter.co.uk/wcss...in-trouble.pdf
    Looks like there are some dip switches or similar that need setting for it to work, its wired wrong, or its the wrong board.
    Oct 2007
    manchester
    5,639
    45
    why was the board changed?- what was the original fault?
    some daikin pcbs req a capacity setplug that tells the pcb the size of the outdoor unit
