Thread: Ranco a10 1463
    Mar 2005
    uk
    54
    42
    Ranco a10 1463
    Does anyone know where I could get a Ranco a10 1463 stat from.its very old and is off an old Jensen interceptor,there is an arm which is worked from a vacuum actuator that gets its signal from the selector switch in the cab.the sensor from the stat goes into the evaporator I am guessing the stat is a fixed set point.looked at Ranco stats there is some that operate within temp range I want but I would like one with the on/off lever on side.does anyone know of anything about these. Thanks
    11,025
    Re: Ranco a10 1463
    All I can find is the VB7 replacement 'stat, sorry.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Ranco a10 1463
    11,025
    Re: Ranco a10 1463
    Thanks Chemical, trouble is I bet he doesn't want 300
    But looking at that picture I'm sure that the operating lever could be transferred from the old 'stat.
