    India
    691
    12
    Air flow for ice storage system
    Does any one had details on providing air flow in the ice store room. What we had seen is some Gi sheets were used all around the room mounted on wooden pieces to provide gaps all around the room including bottom side. The cooling unit air then flows all over the room even below & ice lumps are avoided.
    But that may be a crude design.
    Auckland
    68
    3,362
    32
    Re: Air flow for ice storage system
    Hi smpsmp.
    what type of ice are you storing, general rule is store at temperature slightly below at what ever temperature it comes out of ice maker, store at too low temperature it will end up as one big frozen lump., in bags or bins what ever. Air flow is important as well, racking systems are good for air movement around palletized products. Do not mix flake ice storage with tube ice storage as each is made at different temperatures.
    Can you explain the Gi what evers everywhere ?
    India
    691
    12
    Hi!
    For ice storage rooms, one needs to provide gratings type structure inside to maintain air flow all across the ice. Or else the bottom ice forms lumps. We have seen companies using Galvanized corrugated sheets on four walls & floor which keeps gap for cooling unit air circulation.
    At the same time , due to ice load the floor/ walls can get damaged.
    May be there is a better way of putting up such gratings to maintain proper air flow all around.
    Nov 2009
    france
    58
    139
    12
    Hi smpsmp.
    How much flake ice are you intending to store?
    is it a manual or mechanical unloading system?
