    Feb 2016
    Saudi Arabia
    1
    compressor built for 50 hertz when operated at 60 hertz.
    What is the risk involved when using a compressor built for 50 hertz when operated at 60 hertz. Can we get positive results.
    Sep 2003
    ISRAEL
    66
    4,153
    38
    Re: compressor built for 50 hertz when operated at 60 hertz.
    aii compressors can run on both frequencies, the speed and capacity will increase by 17%.
    Oct 2009
    Norway
    Not all compressors can run on 60hz. You'll get increased speed and higher ampere. Motor temperature will be higher and can damage the motor over time.
