    Feb 2016
    Auckland
    38
    1
    MHI Truck Refrigeration fault codes.
    hey,
    new to R-E.com, so any help will be greatly appreciated.
    I am working on Mitsubishi Heavy Industries Truck Refrigeration TD30 system with a TD-2 contoller.
    I wondering if tere was a manual for the controller and a list for the fault codes. Searched all over the internet for one to no avail.
    Alarm FU1 is appearing.
    again any help would be greatly appreciated.
    Feb 2009
    telford
    2,092
    33
    Re: MHI Truck Refrigeration fault codes.
    Send me your email,got a friend who may know.
    Nov 2008
    Philippines
    56
    49
    FU1 is probably compressor clutch fuse failure. Check also if the terminal of the supply wire from battery is corroded
Tags for this Thread
