Thread: force lossnay to run.
09-02-2016, 04:48 PM #1
good evening .
help please .
i have a LGH -200RX3-E model code 546 658 .
re moved from the ceiling and on a gennie hoist at the moment .
this unit was never serviced as it was not possible to access it thru the tiny hatch and also slammed against a wall with no filter access.
no even a glance at the electrics box .
i do have to see if it will run .
i have put power to it and the bottom pcb board has green flashing led and two red fixed and the top pcb board has no green led and one fixed red led .
i only have a spare par-f27mea controller which is addressable
and one spare par-31maa.
the top part of the unit has a address of ten (10)
and the bottom part has a address of 09
taking that it is no longer part of the m net
i connected my controller (par-f27mea) to the t 2 when powered on via switched plug top the unit makes a few noises and click of relays i presume .
i the controller ho , ho , ho S and nothing .
then the bottom green led goes out after a while .
i did set the remote address to 09 then 10 to see if there is any difference
sadly i do not have a dedicated lossnay controller .
is there any way i can force this unit to run ? or am i doing something wrong any help would be appreciated .
sorry its long winded but i am trying to give all the facts .
due to the state of the inside( filters and cores) i think its toast anyway .
but others may have different plans .
09-02-2016, 09:50 PM #2
Re: force lossnay to run.
whilst looking for some thing on the net .
i came across a lossnay manual from orionair .
which showed on /off operation without remote controller with a link on terminal tm 2 between 1 and 3 terminals .
10-02-2016, 09:53 AM #3
If you have a smartphone with IR sender you can download an app for most of the heat pumps, and use the phone as remote control.
10-02-2016, 01:00 PM #4
Hi Kenneth.
If you have seen my phone you would laugh.
It a old. Nokia speak and text only.
Stays charged for a week.
And I have just got a similar one in mint condition from oxfam for £8.00
My mates got the latest smart phone.
The link on tm 2 worked treat this morning clients could see the lossnay run
So I can take it apart to get it thru a door way.
Cheers .
