    Mar 2009
    Ireland
    McQuay Air-cooled Chiller
    Hi Guys,
    Would anyone have an IOM for the following McQuay model
    ALS 249.2 ST R134a
    I have search the web but keep getting a blank. This chiller uses the Carel controller.
    any assistance would be greatly appreciated.
    Jun 2011
    Australia
    44
    336
    21
    Re: McQuay Air-cooled Chiller
    Hi mate,
    Have a look at my folder, whilst I might not have that exact model everything else I do have will probably cover it..
    https://www.dropbox.com/sh/yjgvet6wb...3ym7yP3Ja?dl=0
    Ps, download what you like but I'm going to disable the link after a day or so..
    Somerset
    69
    4,698
    Sorry HVACRsaurus.
    I tried to give you rep points for your kind assistance / post.
    But it appears I have not issued enough since last giving you some!
    All the same a good and Helpful contribution.
    Mar 2009
    Ireland
    Absolutely outstanding HVACRsaurus. Go to the top of the class. Thank you for that brilliant information.
    I had a look through this website and found this thread which is now closed.
    http://www.refrigeration-engineer.co...xpansion-Valve
    On the second last post the is mentions of a Service Bulletin SPSB03008.
    Would anyone know where I could get my hands on that?
    It appears I will shortly have the same issue as the guys in the other thread. The McQuay chiller I will be working on has an Alco EX8 fitted to each circuit, with one going faulty.
    There are flanged connections on either side of the old EX8, but apparently the new EX8 is brazed on.
    So be nice to get a look at the bulletin.
    Thanks again HVACRsaurus.
    Jun 2011
    Australia
    44
    336
    21
    Happy to hear it, Ta
    Pretty much anything you'd want to know about the EX8 is here;
    http://hnc.ru/lib/a&c%20(automatic%2...EX58e35008.pdf
    Personally, if I was faced with changing one I'd look at retrofitting it to something else.... Maybe Danfoss ICV / ICS combination - various controllers, comprehensive signalling, field serviceable valve insert, removable / replaceable stepper motor & manual opening provision (no affiliation, ps the early ones were sh1t but the "new" ones pretty darn good... Albeit expensive, but good..)
    Pps, service bulletin pretty much say - sorry guys old on is Union but new one is solder, TFB (say this with Borat accent)
