Thread: HC comp change
25-01-2016, 12:20 PM #1
HC comp change
Might be of use
https://youtu.be/Fr5Vl2q3fiw?list=PL...EJyPlt0Hcenq0U
Rob
25-01-2016, 04:19 PM #2
Re: HC comp change
Cheap advert with elevator music.
The first thing to do after emptying the pot is to break all the service tubes, compressor and drier.
Looks like an invitation for leaks.
Nothing beats good brazing.
25-01-2016, 04:19 PM #3
Re: HC comp change
25-01-2016, 09:26 PM #4
Re: HC comp change
I don't trust those lokring things, probably just braze the new one in. Vac the system first and fill with nitrogen, then cut pipes and braze in new components.
25-01-2016, 09:47 PM #5
Re: HC comp change
not lost any eyebrows yet doin pot changes the old fashioned way
26-01-2016, 08:34 AM #6
Re: HC comp change
Removing the Relay... Good luck with not receiving a sting from the start Capacitor. I don't care if the Cap had a bleed resistor or not. Capillary tube wasn't cut properly. Ongoing cooling issues.
Ta for posting Rob
Elevator music Chemi? Here's one we hear. https://www.youtube.com/watch?v=GyEksqCKx2oTo the optimist, the glass is half full. To the pessimist, the glass is half empty.
26-01-2016, 03:19 PM #7
Re: HC comp change
Yes Mike, Richard Clayderman is the king of elevators music.
