Thread: HC comp change
    May 2012
    54
    1,325
    30
    HC comp change
    Sep 2003
    ISRAEL
    66
    4,153
    38
    Re: HC comp change
    Cheap advert with elevator music.
    The first thing to do after emptying the pot is to break all the service tubes, compressor and drier.
    Looks like an invitation for leaks.
    Nothing beats good brazing.
    Sep 2003
    ISRAEL
    66
    4,153
    38
    Re: HC comp change
    44
    3,800
    38
    Re: HC comp change
    I don't trust those lokring things, probably just braze the new one in. Vac the system first and fill with nitrogen, then cut pipes and braze in new components.
    Oct 2007
    manchester
    44
    5,707
    Re: HC comp change
    not lost any eyebrows yet doin pot changes the old fashioned way
    Jul 2010
    NTH.QLD Australia
    56
    1,757
    27
    Re: HC comp change
    Removing the Relay... Good luck with not receiving a sting from the start Capacitor. I don't care if the Cap had a bleed resistor or not. Capillary tube wasn't cut properly. Ongoing cooling issues.
    Ta for posting Rob
    Elevator music Chemi? Here's one we hear. https://www.youtube.com/watch?v=GyEksqCKx2o
    Sep 2003
    ISRAEL
    66
    4,153
    38
    Re: HC comp change
    Yes Mike, Richard Clayderman is the king of elevators music.
