Thread: Hello
30-04-2006, 06:48 AM #1
Hello
I would like to say hello to all. I am new to this so be patient please. I am however looking forward to gaining as much from this site as I give.
30-04-2006, 07:37 AM #2
Re: Hello
Welcome Justin from Belgium, and thanks for introducing yourself. I think you found the best place to learn.
We're now more then 5000 members worldwide.
Have you add your location on the members map?
You better then can see who lives around you.
Look around a litlle bit on this forum through the different section.
May Iask, iIf you post a question, will you add after the IP units the SI units between brackets? Many members are not used to work with IP units.
You can convert them easily with Uconeer http://www.katmarsoftware.com/uconeer.htm and it's free.
This was the first free advice you got.
PeterIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
03-05-2006, 01:57 AM #3
Re: Hello
Ok man I sure will
Justin
