    Feb 2010
    Bulgaria
    38
    36
    Water 300 controller alarm problem
    Hi all ,
    I have problem with Climaveneta chiller/heat pump and the controller
    The machine use Water 300 controller .
    And now shows :
    AL:003 – Evaporator pump thermal protection
    After i reset the alarm manually it shows it again and again .
    Any idea what to do ?
    Oct 2009
    77
    243
    Re: Water 300 controller alarm problem
    Check pump motor and contactor reset overload check running amps
    Sep 2003
    ISRAEL
    72
    4,248
    Could be a thermistor in the pump motor winding.
    See if there extra 2 wires in the motor connection box.
Tags for this Thread
