Thread: I'm onto a winner
04-10-2015, 01:10 AM #1
I'm onto a winner
I think I have found a perfect refrigerant that ticks all the boxes.
Cheap..................................................... check
Environmentally sound................................ check
Stable at most temperatures....................... check
High critical point (374degC)....................... check
Not toxic................................................. check
Cheap..................................................... I think I mentioned that
Reasonably easy to obtain.......................... check
Easy to contain........................................ check
Safety category....................................... can't find one so I think it is A1
Fantastic specific heat properties................ check
ASHRAE approval code............................... R718
Do you think I'm onto a winner?
Rob
04-10-2015, 05:02 AM #2
Re: I'm onto a winner
Our caring multi national corporations can make billions of dollars selling it - No..
04-10-2015, 07:57 AM #3
Chemically stable.
Purity can vary depending on the Country supplying it.
Dangerous if there is a significant leak as it displaces Air.
Suited for Cold room applications. Useless as a refrigerant in Freezer rooms.
Liquid charging only. Reckon i read the same report Rob.Last edited by mikeref; 04-10-2015 at 08:00 AM. Reason: Added some.
04-10-2015, 07:59 AM #4
I remember going into FSW and asking for a bottle of R407C and a bottle of R718....
Blank faces all round
04-10-2015, 08:24 AM #5
04-10-2015, 11:53 AM #6
There are that many people flogging their snake oil,
there must be a magic solution out there, one that
does not rot your livers, corrode the system and does
not kill all the fluffy bunnies in the fields and clouds in the sky.
I'll keep looking, someone is flogging an additive that guarantees
20% improvement in efficiency.
Rob
