    Nov 2008
    us
    67
    5H60 Oil Pressure: Loading/Unloading
    CARRIER has a table in the Installation-Start Up and Service Instructions manual indicating oil pressure ranges for loading and unloading. Would someone please explain that table?
    (5H60 in this case).
    Increasing to load = 20 (step 4), 23 (step 3), 26 (step 2), 30 (step 1),
    Decreasing to unload = 19 (step 1), 16 (step 2), 12 (step 3), 9 (step 4) decreasing to unload.
    Thanks!
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    Re: 5H60 Oil Pressure: Loading/Unloading
    Quote Originally Posted by PLEH2EREH View Post
    Thanks!
    This is not oil pressure, it mention “controlled oil pressure” (COP) for using for cylinder loading/unloading. There is an internal mechanism to develop the COP from oil pressure.
    3,355
    Not sure if this is relevant for adjustment but see unloader adjustment.
    It is just referring to when unloaders on each head active or deactivate in PSI (pressure) increments.
    http://dms.hvacpartners.com//docs/20...0A/530-520.pdf
    495
    21
    Hi like ranger says, when it loads up you loose oil pressure, but when the loading cylinders are full of oil, then the oil pressure comes up to its original pressure, unless you have a leak in the pipeline or cyclinder gaskets are worn or the piston and oil leaks out slowly
