28-04-2006, 07:30 AM #1
is this kind of heat pump feasible
We manufacture evaporative condenser chiller ,in winter it need electricity heating if customer require.
If change the chiller to heating mode the evaporative condenser should be used as evaporator,the surface is not enough. Backup extra surface seems not a wise method. Could you give me some ideas? thanks in advance
best regards
LC
28-04-2006, 11:14 AM #2
Re: is this kind of heat pump feasible
Free cooling is wiser than heating for cooling.
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
frostles heat pump
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM -
heat pump capacity adjust
By Lc_shi in forum FundamentalsReplies: 5Last Post: 14-02-2006, 07:32 AM
