    Dec 2010
    Toronto, Canada
    54
    1,492
    3/16" and 1/4" tubing pressure drop tables
    Does anyone have such a beastie? I can't seem to find anything on the tinterweb
    Auckland
    67
    3,362
    31
    Re: 3/16" and 1/4" tubing pressure drop tables
    Hi Mike,
    check engineeringtoolbox.com there is a load of info available
    Sep 2003
    ISRAEL
    65
    4,114
    38
    Aug 2014
    69
    410
    Hi Mike
    Is this for distributor lead sizing ?
    Dec 2010
    Toronto, Canada
    54
    1,492
    I have to make a 1 ton liquid condenser and I have the tube runs and diameter for a air cooled one. I'm trying to match, as closely as possible, the volume, and pressure drop of the current air one. I will be up sizing the tubing from 4 parallel runs of ~5mm or 3/16 tube to 5/16 tube with perhaps 2 parallel runs. Sound simple enough, haha.
    Engineering toolbox seems to stop at 1/2" tube and the tables I have from Copper institute (not institute of UK policemen), seems to stop there as well.
