Results 1 to 19 of 19
    Sep 2010
    France
    28
    Charging gas with recovery station ?
    Hi guys ( and girls ?)
    I have a stupid question to ask ... Is it possible to use a recovery station for charging gas in a system ?
    I await your answers...
    2,579
    29
    Re: Charging gas with recovery station ?
    Pvl,
    Well maybe, is system running or off.
    It could transfer liquid quite easily, with system on or off.
    What are you trying to achieve exactly , as many scenarios.
    Sep 2010
    France
    28
    nothing in particular. I was wondering because I had a problem where I did not have enough pressure in a cylinder and system off. Does it work well and do not risk damaging the station ?
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Quote Originally Posted by pvl View Post
    there is a special heating blanket for refrigerant bottles. Ask your refrigerant supplier.
    Sep 2010
    France
    28
    I know... I just want to know the possibilities of a station apart from its main function, it may be useful
    44
    3,800
    38
    Yes its possible, i have recovered refrigerant from a system to make repairs, then reversed the process to empty the recovery cylinder back into the system. You could charge new refrigerant the same way if needed.
    Auckland
    68
    3,362
    32
    System repairs after recovery then system should have been evacuated, before re-charging. So dump charge back into high side. Alternatively if your recovery unit handles liquid use it to recharge repaired system in liquid phase. No short cuts.
    Aug 2014
    69
    434
    If you recharge via your recovery unit always fit a solid core drier in the charging hose line to remove any moisture ,acid , debris etc that may be in the old refrigerant , then you know the refrigerant is in a reasonable state for the plant to work with, as you cannot be sure what condition the recovery unit is inside if it has been used on bad systems
    Feb 2009
    telford
    2,068
    27
    Done it on car ac so it should work on anything
    Sep 2010
    France
    28
    thanks for your answers
    May 2012
    54
    1,325
    30
    Recovery machines don't care which way they push the refrigerant.
    From the system to the cylinder or from the cylinder to the system,
    makes no difference to the machine.
    Just make sure you know whether it will pump liquid, if the machine is
    less than 10 years old it should be capable of handling liquid. Make sure
    weigh the refrigerant and follow Glens advice above about fitting a small
    dryer in the line. For the cost of the dryer it is worth fitting one.
    Rob
    ireland
    48
    271
    Also be aware some machines cannot pump virgin gas .
    May 2012
    54
    1,325
    30
    Quote Originally Posted by joe-ice View Post
    Oh OK, why?
    Rob
    Feb 2009
    telford
    2,068
    27
    I don't know of a machine that cannot pump virgin gas? and the drier is a must in both directions it will slow the process down maybe,but only by so little time you would not notice it good advice Rob.
    ireland
    48
    271
    I seen a machine few years ago that was ruined from virgin gas,It relied on the oil in the gas to help with lubrication.When pumping virgin gas it washed the bearings dry.Think the machine was a stinger and the guys were using it to decant big cylinders.Probably isnt an issue with newer machines.
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Refrigerant doesn't get near any bearings, only pistons and 2 valves.
    modern machines don't need any lubrication.
    May 2012
    54
    1,325
    30
    Ah now that is a valid point, but most new versions,
    less than ten years old are all oil free running now.
    It might have been an issue with the older machines
    but I'm sure it's not an issue now.
    I think
    Rob
    Jun 2008
    Albania
    45
    I have a Refco recovery machine and it is oil free so does not harm by oil less refrigerant . But you have to be very carefull about what pressures the recovery unit can reach .
  19. #19
    Oct 2003
    56
    5,519
    28
    check after recovering pressure versus temperature if no non-condensables were not evacuated together with the refrigerant. Seen it many times. in that case, recharge only liquid and let some liquid in the cilinder. The liquid then acts as a seal for the air because you then leave the not wanted air in the bottle.
