Thread: Carrier chiller oil migration
30-04-2006, 04:11 PM #1
Re: Carrier chiller oil migration
Hi Lowtech, check the oil equalization check valve installed in the rotor locking bolt in each of the compressors. You can check the valves by removing the suction filters on the compressors. I hope this helps. Dimitris
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
carrier chiller fault codes
By al in forum Air ConditioningReplies: 7Last Post: 20-07-2009, 10:10 PM -
Trane & Carrier Chiller Data
By mustafa in forum Air ConditioningReplies: 8Last Post: 03-05-2009, 04:10 PM -
Chiller Carrier
By vspiteri in forum Air ConditioningReplies: 11Last Post: 17-02-2005, 07:59 PM
