Hi guys . this unit works for few hours then stops, green light blinks 5 times. i have refer to manual, it says :metal case condenser fan motor causes the grounding of the outdoor pcb.to start the unit again ,they turn it off and then on again, few hours later the same happens, unit stops and gives 5 blink on green light; any idea?
it states if you disconnect the outdoor fan electrical connection and connect it , this will solve the problem, i have not done it yet.
