    India
    688
    Relative humidity in freezer rooms
    Hi!!
    One of our clients is interested in knowing the Relative Humidity in cold store working at -20 Deg C.
    Are there any technical articles on this subject and/ or practical experience of our experienced members?
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Re: Relative humidity in freezer rooms
    Best option would be to get some readings in your store or back engineer the design.
    Sublimation of product at freezing temperatures is well recorded and can be researched on your clients specific product and psychometric conditions calculated.
    RH is depending on design conditions, product and equipment operation.Your dry bulb temperature and evaporation temperature (SST).
    The wider the store TD has been designed the lower the RH and the closer the TD to holding temperature design the higher the RH.
    Poor design on large TD will raise vapour pressure and cause higher product moisture losses. Then there is the design of the air movement to consider. (blast/rapid freezing to holding)
    Freezing rate and Freezing time are a major factor influencing design. First question I always ask a client and then get them to put it in writing. (Change their minds, like their socks. Then wonder why quote 3 from acme bodgit and legit inc. was cheaper and they have problems).
    Sep 2008
    Canada
    811
    India
    688
    Many Thanks
