    Jan 2006
    Norway
    1,036
    4
    31
    pictures of the "slaughter bench"
    All the parts laid out on the "slaughter bench" ready to be cleaned
    and the compressor foundation of my own design, holds anything from an xrv127 to an xrv 204, with access to all the bolts, and place to put the oil collecting trays
    -Cheers-
    Tycho
    3,355
    Re: pictures of the "slaughter bench"
    Tycho can't open for some reason, can someone verify attached ok thanks
    It's ok opened
    Jan 2006
    Norway
    1,036
    4
    31
    had some problems attaching the pictures, your message is kind of cryptic
    so it's working?
    -Cheers-
    Tycho
    3,856
    Works for me, impressive set up!
