Results 1 to 16 of 16
Thread: Auto Air Con
    Aug 2013
    Hampshire
    38
    87
    13
    Auto Air Con
    Is this the right area for auto air conditioning? Does anyone know anything about it?
    Just bought a Jaguar X Type and the air con doesn't work. The compressor physically runs but is not pumping as the pressures aren't changing. It had no gas in system on arrival so I've charged it to the correct amount and no luck. Was hoping for a quick fix but looks like a new comp will be needed at the moment
    Martin
    Dec 2010
    devon
    837
    Re: Auto Air Con
    First thing to do is pressure check these they are prone to condensors and pipes rotting out on inner wings .......how old is it some of newer ones run cluthless comps thus they always spin the front hub let me no age will check me books if it's clutchless u gas it without resetting ecu it won't pump
    Aug 2013
    Hampshire
    38
    87
    13
    Hi it's 2006
    Martin
    Somerset
    69
    4,698
    Re: Auto Air Con
    Charlie you continue to amaze, Martin How many hours you working to buy Jags?
    Aug 2013
    Hampshire
    38
    87
    13
    Is it clutch less Charlie?
    And too many hours Grizzly, thought I'd treat myself as the rest of my life has gone to **** lol
    Martin
    Dec 2010
    devon
    837
    Re: Auto Air Con
    How old is she? I can check I can also check if on Tev or orifice I've had several where people have removed orifice because they assume it's just a filter then u get same pressures just tell me the age please
    Aug 2013
    Hampshire
    38
    87
    13
    It's 2006 model
    Martin
    Aug 2013
    Hampshire
    38
    87
    13
    I can see this taking a while 😳
    Martin
    Dec 2010
    devon
    837
    Re: Auto Air Con
    I will check tomos
    Aug 2013
    Hampshire
    38
    87
    13
    Any luck on this?
    Martin
    Aug 2013
    Hampshire
    38
    87
    13
    I really need to know if I'm buying a compressor or accumulator kit
    Martin
    Aug 2013
    Hampshire
    38
    87
    13
    Ok so now the condenser is getting cold!? Whilst warm air is blowing out in cabin and yes it's set to cold. No pressure difference either side
    Martin
    Dec 2010
    devon
    837
    Re: Auto Air Con
    Sorry for delay just got in anyway it's a clutch assemble like a standard comp so if energised and running and no temp diff at all pull of pipes and spin by hand if no noise from pump pump is shot pencil me ur email and I will give u a number of good cheap supplier
    Aug 2013
    Hampshire
    38
    87
    13
    Ok thanks will do
    Martin
    Aug 2012
    United Kingdom
    12
    Re: Auto Air Con
    Does compressor pump when you Rev it?
    They are of the spiral variety internally and when run low on gas for a while it wears the seal them only works when you Rev it
    Aug 2013
    Hampshire
    38
    87
    13
    Re: Auto Air Con
    no nothing happens at all
    Martin
