    Nov 2008
    canada
    64
    Freezer Floor Needs Cleaning
    I have a large area of floor in a freezer that needs cleaning from storing cranberries. The floor is covered in berry juice and we are looking at racking the room. Raising the temp is an issue currently at -18C any suggestions would be greatly appreciated thank you and have a great day!
    May 2012
    59
    1,528
    Re: Freezer Floor Needs Cleaning
    If you can't warm it up, you can't put water down
    so it will mean just back breaking scraping with a
    floor scraper.
    Rob
    Sep 2003
    ISRAEL
    72
    4,248
    Steam washer.
    Feb 2009
    telford
    2,092
    33
    Vinegar, coca cola that's my advice but you know what they say about advice it's best given away.
    Dec 2010
    devon
    837
    Concrete floor or insulated floor ? If concrete salt will thaw nicely had a room that had blocked a drain and heater packed up ice on about 6m square so put it on extended Df bit of rock salt mop and dry not to much salt did not want to rot a evap if insulated with chequre plate same will do if the insulated wood type not a good idea stains the floor yes learned the hard way
