    Oct 2007
    Nepal
    Question Parallel use of Centrifugal fans in HVAC
    Please advice the best way to use two Parallel centrifugal fans of 4000 CFM, 150 Pa each.
    69
    10,509
    Re: Parallel use of Centrifugal fans in HVAC
    It depends on what you want the fans to achieve.
    Please the fan bible "Woods Flakt Fan Engineering Handbook"
    http://www.google.co.uk/url?sa=t&rct...95039771,d.d24
    Oct 2001
    Nottingham UK
    5,091
    42
    Fans in parallel = double the volume same pressure
    Fans in series = same volume double the pressure
    I'm back on the Pale
    Mar 2010
    Dammam
    83
    8
    It depends on your requirement (flow and sp).
    Operating fans in parallel approx. doubles the flow and increses the static pressure slightly.
    <"No one is so smart, they just stay with problems longer and use their imagination">
    Auckland
    67
    3,362
    31
    dependent on what sort of centrifugal fans you are applying. Brian UK reference to Woods Flak is a good start
