Results 1 to 2 of 2
Thread: CO2 LP only
    Oct 2014
    nORWAY
    34
    1
    CO2 LP only
    could somebody explain how CO2 transcritical booster works in only LP opperation?
    May 2012
    54
    1,359
    30
    Re: CO2 LP only
    I think the booster is what we would call a compound system or
    a two stage system. The LP compressor raises the pressure to the
    MP, pressure.
    To lift the pressure with one comp only is beyond the capabilities
    of a single (piston) compressor so it has to be done in two stages.
    http://www.r744.com/web/assets/compa...ter_system.pdf
    Rob
Tags for this Thread
