    Jan 2006
    Norway
    1,035
    4
    31
    Howden shaft seal replacement
    For the first time in many many years, I replaced a shaft seal on a Howden XRV 127 where the cause of failure was obvious
    usually the seals are in pristine order and have less than 500 running hours, so this was a nice change
    This one has maybe 10 years on it, but it was a ***** system...
    -Cheers-
    Tycho
    3,357
    Re: Howden shaft seal replacement
    Tyco, appears very dirty for a ***** system, maybe something else wrong as well!
    Sometimes you can get localized heat generation in seal area, what the rest of the system look like?
    Jan 2006
    Norway
    1,035
    4
    31
    This was a bit tongue in cheek to all the shaft seals we have replaced that are in pristine shape after 500-100 hours on ammonia systems
    This shaft seal has over 20.000 hours on it, it was on a Russian ship and they have just left it there because it's a ***** system and not ammonia, so it didn't smell when it started leaking
    -Cheers-
    Tycho
