Results 1 to 18 of 18
    Jun 2008
    Iraq
    55
    29
    MC Quay (McEnergy AXN Chiller problem)
    My respectful colleagues,
    Hope all are good.
    I have air cooled McQuay chiller type McEnergy A 166.2 XN 134.
    the chiller shows the alarm " #1 EXV not closed during power OFF ".
    Then when go to unit setting system 1 expansion valve shows other message " EXV setting #1 system's waiting for valve open restart go a head ? N."
    If you please open the attached images with my thread.
    I changed the battery ( the battery was not good) and checked the EXV motor which is working fine.
    I checked the Carel's EXV driver. the LEDs are showing that " the valve open in case of lack of supply"
    ( LED open: flashing/ LED close: flashing / LED power: ON / LED alarm : flashing ).
    I need the Tech Password" to restart the EXV again.
    The password consist of 10 separate digits. (00000 00000).
    Hope someone will help and I'll be appreciated.
    Wish you all good day.
    Aug 2013
    Hampshire
    38
    87
    13
    Re: MC Quay (McEnergy AXN Chiller problem)
    Hi can you try 40130-40145 please, or press + = - help. And may I ask are there any side effects of this problem to the system other than the fault code?
    Martin
    Jun 2008
    Iraq
    55
    29
    Thanks Martin,
    Side effects, the battery wasn't good and also alarm B6 the high pressure transducer.
    Saturday I'll try your password.
    By the way, I know the keys +/ - but the mark = don't have or know about it.
    Regards.
    Aug 2013
    Hampshire
    38
    87
    13
    Is the unit still running ok or switched off? And is there also a solenoid valve fitted?
    Martin
    Jun 2008
    Iraq
    55
    29
    Hi Martin.
    System #2 still running but the system #1 stopped by the alarms "EXV. not closed during power OFF" and " EXV #1 battery error". There are solenoid valves for the economizer and capacity control on the compressor only and there is no S.V before the EXV.
    Aug 2013
    Hampshire
    38
    87
    13
    From what I've read about this online and other forums it sounds like you might have trouble accessing the controller without knowing the specific password and some controls are only accessible through a mcquay engineer with a laptop and software but good luck!
    Martin
    Oct 2012
    Russia
    42
    392
    01331 07211
    Jun 2008
    Iraq
    55
    29
    Thanks Martin for your support.
    Quote Originally Posted by Martin Davies View Post
    Jun 2008
    Iraq
    55
    29
    Thanks >>>> I'll check the password. With regards.
    Quote Originally Posted by RusBuka View Post
    01331 07211
    Jun 2008
    Iraq
    55
    29
    Hi Martin, Rus
    I entered the passwords but they did not give access.
    Hope I can find new more password.
    I just want to give the order "YES" to make restart for the EXV. to verify again the zero point.
    Thanks anyway. I'll not stop and try more and more.
    Oct 2012
    Russia
    42
    392
    heh you need new firmware)
    Apr 2011
    Russia
    139
    15
    Hamooody, try another one 1331721125
    Jun 2008
    Iraq
    55
    29
    Thanks Alex. I tried this before, and no response to it.
    Quote Originally Posted by AlexG View Post
    Jun 2008
    Iraq
    55
    29
    Rus, Tell me;How do you that??
    Oct 2012
    Russia
    42
    392
    Remove old firmwire and load new) But you need to kick some ass in McQuay., whey dont give firmwires to anyone.
    Soft for that operations you can find on KSA. Carel.
    But if you never do it, dont try))
    Jun 2008
    Iraq
    55
    29
    Hi Rus,
    Today I tried another way to get an access to the tech. password. It is work fine and later I used your password and it works. Thanks to you for inspiring me to find the correct way.
    So, here let me also thanks Mr. Martin and Alex. Have good day.
    Oct 2012
    Russia
    42
    392
    You put new firmwire.?
    Jun 2008
    Iraq
    55
    29
    Hi Rus,
    No, I went to manager level and I entered the operator access password "100", then go to technical password I pushed up and down arrow together to rest the password. Later I entered your password and then I got access to technical level. Turn the letter N to Y " yes" the problem solved EXV worked but still need to change the EXV driver battery though the old battery read 18 volt dc. but the controller generate the alarm " EXV.#1 driver battery error". And when I use the other system's battery the alarm gone . Nice day
