07-05-2015, 10:31 AM #1
DIY - Refrigerant Recovery Machine - help needed
Hello everyone.
I've been looking for a recovery machine in my part of the world, even a used machine is so expensive that I can't even think about buying one of those as of now.
So, I went about searching how can I build one myself
I have most of the things, including the compressor, condenser - piping is of course no issue...
but I need a general diagram of such a unit plus =
how to remove oil from the refrigerant?
what to use as sep tanks? - where to install the seperator tanks things like such
how to inject the recovering refrigerant into a cylinder
need general guidelines so I don't blow anything up
regards
10-05-2015, 12:20 AM #2
Re: DIY - Refrigerant Recovery Machine - help needed
We used to use old condensing units, one for 407c, another for 134a, might be easier than trying to work from scratch?
10-05-2015, 11:45 AM #3
yes, but I work in the automotive industry, don't have access to such things as you guys do
I have the compressor, condenser and all the piping needed
just need a basic diagram or flow chart - plus where to install sep tanks ideal locations etc would be very helpful
