    May 2014
    Lahore
    29
    15
    DIY - Refrigerant Recovery Machine - help needed
    Hello everyone.
    I've been looking for a recovery machine in my part of the world, even a used machine is so expensive that I can't even think about buying one of those as of now.
    So, I went about searching how can I build one myself
    I have most of the things, including the compressor, condenser - piping is of course no issue...
    but I need a general diagram of such a unit plus =
    how to remove oil from the refrigerant?
    what to use as sep tanks? - where to install the seperator tanks things like such
    how to inject the recovering refrigerant into a cylinder
    need general guidelines so I don't blow anything up
    regards
    ireland
    47
    1,279
    33
    Re: DIY - Refrigerant Recovery Machine - help needed
    We used to use old condensing units, one for 407c, another for 134a, might be easier than trying to work from scratch?
    May 2014
    Lahore
    29
    15
    yes, but I work in the automotive industry, don't have access to such things as you guys do
    I have the compressor, condenser and all the piping needed
    just need a basic diagram or flow chart - plus where to install sep tanks ideal locations etc would be very helpful
