25-04-2006, 04:23 AM #1
P8 message on Control Board Mitsubitsh mr Lim
Hello
I am servicing a unit(Mr. Slim) which is a ductlee made by Mitsubitch. The control board (thermostat) displays the code P* does any one what is that
25-04-2006, 06:50 PM #2
Re: P8 message on Control Board Mitsubitsh mr Lim
hiya i think p8 is a pipe sensor fault, dont hold me to it but im quite sure off the top of my head...its either faulty or not there at all or not sensing the temperatures its looking for e.g. short of gas...
25-04-2006, 07:29 PM #3
Have a look at this thread http://www.refrigeration-engineer.co...ighlight=mitsi
25-04-2006, 07:53 PM #4
is a p8 fault just not an outdoor fault?
25-04-2006, 08:01 PM #5
P8 means "Abnormality in Outdoor Unit"
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
Areas to check
1 Check continuity of the interconnect wiring - look for breaks (I've had it where rats have chewed the wiring before )
2 Check the phase rotation - has any work been done on the unit mains wiring?
3 Has any safety activated? Compressor klixon? LP switch? HP switch, Fan overload? etc.
4 Measure the resistance of the coil sensor
If you are still struggling then give Mitsi Technical a ring 08703000300
25-04-2006, 10:13 PM #6
A list of Mitsi fault codes is available here:-
http://airconwarehouse.co.uk/Techmanuals.htmBrian - Newton Abbot, Devon, UK
Trane HP Defrost Board Problem
By FastEd in forum Heat PumpsReplies: 8Last Post: 05-09-2008, 01:30 AM -
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Searle cellar cooler control problem
By iceman007 in forum ElectricalReplies: 6Last Post: 06-07-2004, 08:57 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
