    Mar 2009
    cardiff
    33
    Tonon forty water chiller ,HELP
    Model galaxy 154
    This unit has an error code acf9 which equates to a parameter fault. The other fault is aefl which is a flow error even though the pump isn't being given a run signal
    The controller is a dixell ipro chill with xweb 500.
    What I really need is pass codes so I can access and interrogate the controller and find out if anyone is familiar with this thing
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Tonon forty water chiller ,HELP
    Default code is 321
    Mar 2009
    cardiff
    33
    Cheers chemi , il give that a go tommorow
    Mar 2009
    cardiff
    33
    Unfortunatly that didn't work. Thanks anyway
    Sep 2003
    ISRAEL
    72
    4,248
    Sorry, try contact Dixel UK, they might be useful.
    Oct 2007
    manchester
    5,639
    45
    1234 is level2 password
    phil2424's Avatar
    phil2424 Guest
    Hopefully your issue sorted? If not....Dixell Ichill series can be a problem because custom passwords can be set by users. Try default password 1 level 1, 2 level 2, 3 level 3.
    Probably best to view and set parameters through XWEB, rather than on controller keypad.
    If your XWEB has remote access through IP address - you can set up the Dixell controller from remote location....I could do it from Australia!
