Results 1 to 2 of 2
    Jul 2014
    united kingdom
    8
    LG Air con unit issues....
    Hi there
    I need some help here please.
    I have a LG Air con unit (Model LG S12AHP / AS-H1264DMO) that was working fine. But now it keeps on blowing the main fuse on the fuse box.
    I have tested the wires from the fuse box to the Air con unit and they seem fine.
    There are no breaks in wires at all.
    Upon testing everytime i switch on the unit the fuse blows straight away.
    Then i disconnect the compressor and switched on the AC unit.
    The indoor unit worked fine blowing normal temp air. The outside box cooling fan was working too....
    So, would i be right in saying that the compressor has failed and i need to replace it or could it be anything else that i have over looked...??
    By the way - tha capacitor looks ok - no signs of damage etc. When i tested it the capacitor it gave me the correct readings.
    Any help would be much apprciated.
    Oct 2001
    Nottingham UK
    5,667
    Re: LG Air con unit issues....
    Have you carried out an insulation test on the compressor?
