Thread: M10 x 0.75
    Nov 2006
    708
    M10 x 0.75
    Hi Guys
    Does anyone know where to by the above fittings that connect to the danfoss KP5A pressure switch capillary ??
    Aug 2014
    75
    508
    Re: M10 x 0.75
    Hi Quality
    You can get them from Dean & Wood or Climate Centre code no 060-0078 plus adaptor code no 060-0141 Kr Glenn
    Nov 2006
    708
    Re: M10 x 0.75
    I can`t seem to find anyone who sells the fitting on its own. Dean & Wood don`t I will try climate tomorrow
    Sep 2003
    ISRAEL
    72
    4,248
    Re: M10 x 0.75
    You can make it yourself by brazing the right parts together, it will save you time and money.
    Aug 2014
    75
    508
    Re: M10 x 0.75
    Hi Quality
    Those are spare part code nos and they do sell them , quote those numbers
    Nov 2006
    708
    Re: M10 x 0.75
    Thanks, can`t braze because its for ammonia
    Aug 2007
    Adelaide Australia
    70
    562
    Re: M10 x 0.75
    Hi Quality
    I think what Chemi means by brazing is silver soldering, you can use Blue tip silver solder to weld steel to steel for Ammonia as long as you make sure it is clean and you use No 2 flux and the capillary protrudes about 25 mm inside the tube.
    The standard Danfoss capillary lines come with a fitting on either end (060-116166), if you need to extend the length get some steel hydraulic tube cut the capillary and silver solder the extension in.
    Danfoss also sell the weld nipples that have the nut (060-116266).
    Paul
    Born to fish, forced to work
    Nov 2006
    708
    Re: M10 x 0.75
    I managed to track some down the new part number is 060-1064 that's for the 1/4 npt x M10 x0.75 fitting and little aluminium gasket
