    Mar 2014
    Australia
    36
    Red face Inverter Compressor Tester
    Hi all,
    We sometimes get callouts to find a compressor over current fault on inverter heat pump splits. It would be nice to be able to prove the compressor is actually faulty before suggesting we replace it.
    We always do the usual tests, insulation resistance, check windings between each other, has it been tripping the breaker etc.
    We have had situations where clients have requested we replace the inverter module (to save $) before progressing to replacing the compressor. (Obviously we have pre-warned them of the risk they take)
    A few times this has been successful, inverter board replaced, compressor running normal current draw, no more error codes, no call backs.
    Is there a device which we could use to supply a digitally commutated power supply to prove the compressor is actually faulty?
    Please note I am not referring to an inverter board checker with LED`s.
    I am referring to a device to drive the compressor independent of the units control system.
    Feb 2008
    502
    21
    Re: Inverter Compressor Tester
    can you not buy a normal motor inverter and wire the compressor to it and slowly start it
    Mar 2014
    Australia
    36
    Quote Originally Posted by martinw58 View Post
    Thanks for the reply Martin
    I will have a ``Google`` around and see what i can find.
    Feb 2008
    502
    21
    let us no how you get on
    Jun 2013
    Norway
    10
    Mar 2014
    Australia
    36
    Quote Originally Posted by PMS View Post
    Thank you for the responses.
    Feb 2015
    uk
    36
    daikin and mitsi do them as well and fluke do a multimeter that will measure inverted ac current
