Results 1 to 21 of 21
    Mar 2015
    Philippines
    10
    Wiring a Embraco Compressor
    hi
    I recently salvage the compressor from my old F&P ref and the model is Embraco FGS 70HAW, its a 220v unit
    I want to turn it into a mini air compressor to pump bike tires.
    I tried the compressor with the attached circuit and it works. Is there a way to wire the compressor directly without using the circuits ?
    The compressor has 3 wires leading to the circuit board
    The mains, well has 2.
    correction there green wire is actually green and yellow = ground wire
    Compressor : Orange, Blue and Brown (Green and yellow stripe= ground)
    Mains : Black and White
    Thanks !!!
    Dec 2011
    36
    131
    8
    Re: Wiring a Embraco Compressor
    Surely with lack of suction cooling the compressor will overheat and cook the windings??
    I cant see this working mate, the motor has NO cooling.
    Craig.
    Mar 2015
    Philippines
    10
    i need to run it about 2 minutes per application, maybe less would over heating the windings still be an issue ?
    May 2012
    54
    1,325
    30
    See
    http://www.embraco.com/desktopmodule...ivos/02003.pdf
    Your model is in there and there is a wiring diagram.
    You need a small air filter on the suction, anything will do
    but just stop solids like dust a grit getting in also if you
    can drill a hole at the bottom and solder a plug in so you
    can change the oil regularly.
    I have seen refrigeration comps used as air compressor
    and I have seen them run for years with those modifications.
    Rob
    Mar 2015
    Philippines
    10
    I have already installed a scooter air filter at the intake.
    Thanks for the link
    Mar 2015
    Philippines
    10
    Okay I read the manual, understanding it is a different matter. I was wondering if anyone can provide instructions that a 6 year old can follow... like
    The unit is a 220volts unit
    1. Connect compressor blue wire to capacitor blue wire
    2. Connect capacitor Brown wire to mains
    3. Connect Compressor orange wire to mains
    4. Disregard compressor orange wire.
    Something like this would be appreciated.... thanks
    Mar 2015
    Philippines
    10
    The compressor has 4 tubes that is cut and 1 is sealed. 1 is input and another is output, those 2 are working, but the other 2 does nothing. Is that cooling suction ? Do i just seal them shut ?
    May 2012
    54
    1,325
    30
    Quote Originally Posted by qguy View Post
    Photo and post a link so we can see.
    Rob
    Mar 2015
    Philippines
    10
    May 2012
    54
    1,325
    30
    Right the 2 lines at the bottom are oil coolers.
    Isolate and make safe, they won't be needed.
    The comp body has 3 pipes 2 largish and at the same height.
    These are the suction, use one with the filter and either plug
    the other or use as an oil filler?
    The third (smaller pipe on the body of the comp, it will be at
    a different height, is the discharge. connect this to your tyre
    inflator.
    The electrics. The white electrical box is the stat and other control
    equipment. You need the white flex to the comp body.
    Disconnect the white flex from the white box and wire it into an electrical
    mains plug (in the UK we call them a three pin plug because it has three pins
    but your mains plug will be different).
    The electrics. have 4 cables in the white flex, you need three. At the comp
    end one cable is sticking out? This is potentially unsafe.
    Remove the black plastic lid off the comp terminal box and photo the
    connections. We will then be able to look at the compressor connections.
    Rob
    44
    3,800
    38
    Just be careful with it when you are using it to fill tyres, the compressor will easily pump up to 350psi, enough to burst tyres etc.
    Mar 2015
    Philippines
    10
    Correction, green wire from compressor is actually green and yellow = ground wire
    So we have
    Brown, Orange and blue
    Mar 2015
    Philippines
    10
    Brown wire is attached to terminal labeled 2 at compressor
    Orange Wire is attached to terminal labeled 3 at compressor
    Blue wire is at the bottom and could not find any label on it
    Auckland
    68
    3,362
    32
    I cannot believe what I am reading. Advising some one how to pump up tyres on a bike FFS
    Mar 2015
    Philippines
    10
    huh ? confused....
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    439
    26
    or is it how to wire a single phase compressor?
    Brown compressor connect to your mains live (Brown or red usually) and neutral blue compressor connects to mains neutral (Blue, black)
    Capacitor blue to orange, brown joins your brown, live in a three point junction. (check capacitor polarity yourself)
    Don't touch any live wires electricity BITES!
    May 2012
    54
    1,325
    30
    Recycling
    Rather than throw away the comp he is taking the initiative to reuse old components
    and get the maximum potential. Either way the compressor is a gonner, but at least
    this way he may get a few months or even a few years out of it.
    Safety is first and foremost, the electrics need doing properly and safely,
    but with a little encouragement, why not reuse it.
    I have seen this done many times and have done it myself. there was even
    a company in the UK that put fridge comps on a small receiver and sold
    it as a commercial tyre inflator.
    As long as he does it safely I can't see the issue.
    Rob
    Oct 2010
    Australia
    88
    9
    Tip the oil out of it and replace it with mineral oil. POE oil (which it is likely to have) is horrifically hygroscopic and can break down into acids. Also, be aware that the air you push into your tyres will have a fine oil mist in it. Not a terrible issue as even normal piston compressors discharge oily air, but the air from a fridge compressor is *considerably* more oily.
    People have already mentioned the potential pressure issue. If you were really keen you could get a 120psi pop off valve for a couple of bucks from E-bay and plumb in a brass tee into the discharge with the valve in it *just in case*. 350psi into a bicycle tyre will make a frighteningly big bang when it goes off. On the other hand, grenading a 2L coke bottle brings the neighbours running from 4 houses away and makes a fun party trick.
    But seriously, replace the oil. If you can't get your hands on some 4GS mineral oil, ISO68 compressor oil from any auto parts or hardware store will do a sterling job.
  19. #19
    Mar 2015
    Philippines
    10
    Thanks for all the advice on the oil. Will do that tomorrow. I have rewired the it and it works like a charm !!!
    Here are some photos of the end product
    All ready to go
    Again thanks for all your advise
  20. #20
    Oct 2010
    Australia
    88
    9
    Nice work. Another compressor saved from the shredder.
  21. #21
    hookster's Avatar
    Apr 2007
    Hampshire
    439
    26
    nice work, like the little air filter in discharge line good touch!
    I hate the throw away society these days, everyone just wants to bin it rather than fix it!
