    andyhalf's Avatar
    andyhalf Guest
    Samsung srs2029css no chilled water and fridge too warm
    Hi can anyone help with the service manual and any suggestions for this please.
    When i press and hold the two top buttons i get a horizontal dash across the bottom of the right hand display but i have no error codes.
    Worst bit of all it's my own fridge freezer!
    Andy
    4,697
    Re: Samsung srs2029css no chilled water and fridge too warm
    Hi Andy.
    I am not sure just a owners manual will help. However it is the only type I can find so far.
    Follow the link if needed?
    http://www.samsung.com/uk/support/model/SS20SP1/XEU
    Good Luck.
    manchester
    5,639
    rs21 panel if it helps
    fridge evap fan- usually froze up, someone tried jamming too many beers in there?
    Apr 2015
    1
    I have the same and I have taken the unit to bits. I think its the defrost issue that comes up on the forum many times.
    I have bought 2 spares from Amazon for it http://www.amazon.co.uk/gp/product/B...=A6769Y1HDOYF9
    and this
    http://www.amazon.co.uk/SAMSUNG-Frid..._bxgy_kh_img_y
    The unit was all iced up.
    BUT I HAVE FOUND SOMETHING A LITTLE MORE SINISTER
    The black tape or covering around thw wires has melted to the point of dripping down over the element below. I had heard these units had a recall because they set on fire, I guess this is the case here!
    Anyone heard of the issue with the fire? Here is a picture of it melted https://www.dropbox.com/s/kdjbbqthc1...81020.jpg?dl=0
