Results 1 to 2 of 2
    Mar 2015
    United Kingdom
    1
    Post Whirlpool S20BRSS31-A/G American Fridge Freezer Tripping RCD
    Morning Guys
    Moved fridge from one location to another now each time it is plugged in it trips the house circuit breaker RCD
    Having searched on this forum and youtube i have carried out the following continuity tests and readings from the multimeter
    disconnected heater defrost element fridge then powers up, but the fan, compressor etc does not run
    continuity test set to bleep, on the fan i get a reading of 232 but no audible bleep from the multimeter :?
    continuity test again on the defrost heater element i get a reading of 86 but again no audible bleep from the multimeter :?
    continuity test carried out on the thermal cut off after having put it in another fridge freezer we have to prove if it works, i get a reading of 0 and the multimeter bleeps. I have then proceeded to warm up the thermal cut off i then get a reading of 1 and no audible bleep
    Any ideas what could be at fault? or is there anything else i could test?
    Oct 2007
    manchester
    5,639
    45
    Re: Whirlpool S20BRSS31-A/G American Fridge Freezer Tripping RCD
    i gather your testing resistance on the heater fans etc, rcd protect from shorts to earth , ie nicks in cable, u need a megger or a pat tester to identify whats at fault
