Results 1 to 13 of 13
    Mar 2009
    Mancheser
    55
    Advice/help required for a "change over " system In a Comms room
    Hi all, I am trying to come up with some sort of "change over" unit for a Comms room.
    I have two seperate wall mount mitsubishi split systems both serving the same small area. There is only a need to run 1 unit at one time to cool the area, the second just there for back up (critical Comms equipment). Idealy I want to alternate them on a weekly basis, and have the second come in when the temp rises above the set point in high temperatures or if the current unit goes into fault.
    I am aware the par 31 is capable of managing this, but these units are 8 years old and the software is not compatable.
    I think mitsu supply a stand alone panel that will do all this and more, but it's very expensive. So I'm hoping there is an alternate solution.
    manchester
    5,639
    Re: Advice/help required for a "change over " system In a Comms room
    stick a room stat to switch the live s1 to indoor if temp reaches above 23 deg so you have a run/stand by-but 1 unit would run constantly
    As per IM, and add one of those relays that is powered both ways and a 7 day time clock to switch lead lag arrangement.
    Feb 2015
    30
    We use the Mitsi Procon RS panel and A1M interfaces to do this, but like you say it's an expensive way of doing it.
    Oct 2008
    newbury
    1,444
    4,697
    Good post RB Thanks I have saved them for future reference.
    Feb 2015
    30
    What sort of price are these compared to a Procon?
    Oct 2008
    newbury
    1,444
    you want me to wipe your a*se as well?
    Feb 2015
    phillipines
    1
    can I ask question about refrigerator?
    Feb 2015
    30
    Quote Originally Posted by fred View Post
    I wouldn't, r.bartlett might have a hissy fit again
    Mar 2009
    Mancheser
    55
    I looked at something similar to these where a company will build a panel to suit
    your requirements, but it worked out similar costs to the pro con rsns
    Good pieces of kit tho if the customer is willing to pay
    Mar 2009
    Mancheser
    55
    Thanks for your input, isnt S1 the Comms to the outdoor?
    Feb 2015
    30
    S1 live, S2 neutral, S3 is comms. Switching S1 will cut power to the indoor unit, causing it to switch off.
