Results 1 to 13 of 13
    Feb 2015
    Wirral
    7
    Compressor question
    Hello all I'm new to the forumn and im not an air con or fridge man im an electrician working in an fm world so work with a lot of fridge guys anyway my question is how do you mechanically test a 3 phase compressor and is there such a way I'm well aware of how to electrically test. Your thoughts please and I look forward to learning much more of you guys in the future thanks in advance
    Nov 2008
    scunny!
    29
    302
    Re: Compressor question
    Quote Originally Posted by Farmelectrics View Post
    I thought an electrician would know this ?
    Feb 2015
    Wirral
    7
    Jon Jon I have tested the compressor electrically for a fridge engineer who didn't no how to test it he was saying to me that it could be still mechanically damaged hence my question is there a way of doing this or is the guy talking rubbish
    Feb 2015
    Wirral
    7
    Apparently the above compressor is now damaged even though when I tested it with my mft it was ok so back to my question how can a compressor be mechanically damaged go easy I'm not a fridge guy lol
    Feb 2015
    Wirral
    7
    I'm now gathering the only way to test a compressor is by using a multi meter and or a megger is that right
    May 2012
    1,264
    28
    to test a comp electrically, you need to test like you have.
    Test to earth and test across the windings, if all tests ok the
    compressor could still be seized so pulling Full Locked Rota Amps.
    If the compressor is mechanically faulty it would be ok electrically
    but would not rotate or if it was rotating, it might not be pumping.
    Rob
    43
    3,795
    38
    For mechanical testing it would be running it, listen for noises, see how well it pumps into a vacuum and how high the head pressure can go, watch the run current doing this. Shut it off and see if any refrigerant bleeds back across the compressor (note that its normal for some to do so in scrolls and rotaries)
    If it sounds like this its bad,
    https://www.youtube.com/watch?v=EpOZXEfByfE
    Nov 2008
    scunny!
    29
    302
    Sorry read it wrong I thought it said how do you electrically test
    Feb 2015
    Wirral
    7
    thanks for replys chaps not trying to invade your world of refridgeration ha ha happy as a spark just trying to learn basic stuff thanks again
    Feb 2015
    Wirral
    7
    out of interest what would cause the compressor to seize
    2,506
    27
    Liquid flood back
    No oil
    to hot lack of refrigerant
    To name a few
    Aug 2014
    69
    424
    Hi Farmelectrics
    I wrote a series of short lectures on WHY COMPRESSORS FAIL there are 9 parts to the series. You can get them from the Danfoss.com website, Business Areas, Refrigeration & Air Conditioning , Technical Literature,Field Service Tips, Field Service Notes , you will see a no of Field service notes that I wrote before I retired from Danfoss. These may be helpful for your further knowledge into refrigeration Kr Glenn. Any problems finding them let me know and Ill send them direct by email , ps These are also on Google under Glenn Moore Why Compressors Fail
    Feb 2015
    Wirral
    7
    thanks for your help glenn
