    Feb 2015
    2
    Help!!! How Do I Convert OFN from Litres into Kilograms?
    Hi, I'm trying to understand about refrigeration and a need to know what 1 litre of Oxygen Free Nitrogen (OFN) is in kilograms?
    Mar 2006
    Lancashire
    1,869
    Re: Help!!! How Do I Convert OFN from Litres into Kilograms?
    Quote Originally Posted by Wookey View Post
    Can I ask why you need to know this? This is more chemistry than refrigeration.
    However using the ideal gas law, PV=nRT and then rearranging to find the moles of gas: n = PV/RT will help you to get to your answer.
    Marc
    Feb 2007
    2,477
    38
    1 litre of OFN will be very similar in weight to air, 0.000001 providing I got my decimal point right... 1kg/m3.
    But... Why???
    Mar 2006
    Lancashire
    1,869
    1 cubic meter of air at STP (standard temperature and pressure) weighs 1.293 kg.....I think
    Marc
    Sep 2003
    ISRAEL
    65
    4,116
    38
    work it out:
    in a ofn bottle with a volume of 50 liters at 200 Bar, there are 6000 liters of gas, i will find out the weight tomorrow when I will be in the factory
    Found this page:
    http://www.airproducts.com/products/.../nitrogen.aspx
    Feb 2015
    2
    Thank you, I'm a layman (or rather laywomen) really, so not a refrigeration engineer, but trying to understand about refrigeration and how it works and understand parts used and functions, etc. So jumping straight in at the deep end to trying work on thermal dynamics without any prior knowledge! There's only so much information that I can get from the Internet. So appreciate all of your intelligent and educated replies.
    Oct 2008
    newbury
    56
    1,355
    29
    I am thinking you've led yourself up a blind alley. Google 'basic refrigeration diagram' that is the best place to start
