    Aug 2014
    43
    Heatpumps for swimming pools accent air???
    hey all, I have a few sites with accent air heat pumps for swimming pool heating but there buckets of SHT and keep failing on the heat exchangers due to the plastic outer deforming from heat and melting over time.
    any one work on thease and had the same issue??
    can you use the daikin altherma units for this application as I need a -10 rating as it snows here...
    cheers
    PS if this is posted in the wrong section please advise
    Oct 2001
    Nottingham UK
    5,668
    Re: Heatpumps for swimming pools accent air???
    Any heat pump will do the job if you have the right heat exchanger.
    Aug 2014
    43
    frank this is correct however I don't,
    so im trying to work this one out and wondering if anyone else has had these issues and what others are using
    Feb 2008
    Portugal
    207
    We supplied and fitted many pool heater we are a disbutor for Gullberg&Jansson really good quality from Sweden email me and I can send info
    download my vcard for the address
