Results 1 to 9 of 9
    Dec 2011
    romania
    Milky refrigerant
    we do have 2 heat pumps, installed, working fine. But looking to the eyeglasses, on both sides high/low (pictures attached), the refrigerant looks milky ... not clear.
    ( R22 )
    any advice wellcome
    Thank u
    Somerset
    69
    4,697
    Re: Milky refrigerant
    Hi.
    Call a non European refrigeration Engineer.
    Basic stuff this, which makes me question what YOU do for a living, and being R22.
    Further compounds that question.
    Oct 2007
    sweden
    93
    Humidity indicator button in middle of sightglass shows magenta and magenta on label on sightglass shows Caution - ie you have lot of water/humidify long way over 200 ppm circulating in system and this is not good at all....
    I surprise equipment still working ie seem in very bad condition inside...
    System need checking why humidity coming in inside system (if system is water cooler, is good guess you have leak in evaporator for cooling water), empty out refrigerant (for destruct), repair leak, vacuum in possible days, replace drierfilter _after_ some days vacuum pumping (or new driefilter going to saturate immediately depend of very high water content in system) vacuum again to low steady level, leak check before filling new refrigerant.
    If in Europa - you cannot fill with R22 again and need convert system or using drop in refrigerant for R22 with lower efficient and capacity.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by housedoctor View Post
    ( R22 )
    any advice wellcome
    Thank u
    Heavily contaminated with Moisture. It's a serious problem that WILL sooner, rather than later be responsible for an expensive repair bill.
    Refrigeration basics 101. No moisture allowed in any refrigeration or A/C systems.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    housedoctor. I believe you could learn from a series of Utube video's posted by one of our respected forum contributors.
    Here's a leg up to his video's.... https://www.youtube.com/user/heavydiesel
    Dec 2011
    romania
    Thank you for the feedback, I try to add also some movies
    Dec 2011
    romania
    https://vimeo.com/119413991
    looks like oily ...
    Dec 2011
    romania
    Dec 2011
    romania
