    Mulyadi's Avatar
    Mulyadi Guest
    Basic Charging Procedure
    Hello Guys,
    I am new to this field.
    Can Anyone give me Detail procedure on how to vaccum
    (How much Psig of vaccum etc ) and how to charge my
    Freezer Bitzer Type VI ***** R 22 System ?
    Oct 2004
    Scotland
    1,454
    Re: Basic Charging Procedure
    NO, if you don't know , don't do it!!
    Call your local Fridgy to sort it out for you.
    Chillin
    and go get a cuppa
    Mulyadi's Avatar
    Mulyadi Guest
    Well, If I call them it's mean I do not need to join this forum right ?
    Anyone else could help. thx.
    11,025
    I think the point of the reply was that to buy all of the equipment that you need, vacuum pump, pump oil, manifold set, Torr guage, weighing scales, thermometer and probes, p/t comparator, refrigerant, electric amp meter, PPE equipment etc that is probably cheaper, as well as safer, for you to employ a professional.
    Dec 2005
    Johor
    151
    Hi adi
    What are your definition on vacuum?
    Procedure, make sure before you vacuum any system. Make sure no leak presence from the system. During vacuum process, allow vacuum pump oil change at least every 3 hours. Get a vak check to measure the micron level and value. Hold vacuum at least 6 hrs to monitor the changes that takes place. If the micron value maintain and hold, break vacuum.
    Apr 2006
    1,620
    Vacuum to a minimal of 100Microns, 50 is better.
    The rest you should know by now
  1. 410a charging
    By gwilliamson in forum Air Conditioning
    Last Post: 17-11-2010, 05:03 AM
  2. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  3. procedure for chillers testing......
    By drk_in in forum Fundamentals
    Last Post: 17-02-2006, 08:47 AM
  4. Charging formula
    By zimbo in forum Trouble Shooting
    Last Post: 28-12-2005, 10:11 PM
  5. Vacuum procedure
    By Peter_1 in forum Fundamentals
    Last Post: 09-07-2005, 08:50 AM
