Results 1 to 2 of 2
05-02-2015, 07:43 PM #1
samsung sr-s2028cvw internal fan not working
Hi hoping someone can help ive got a samsung sr-s20208cvw fridge freezer all is working but the internal fans on both freezer and fridge ive checked voltage and got a reading of 7.67volts at the fans and also checked fans they also working . the problem is the voltage is to low to run the fans and if fans arnt running its not getting down to temp as all cold air is staying at bottom can anyone help why they are not working is there a sensor that could be faulty or main pcb fault any advice please as im at a dead end
thank you Andy
22-03-2015, 06:23 PM #2
Re: samsung sr-s2028cvw internal fan not working
Hi Avatar
have you checked the door switch ?
Tariq
