Thread: Thermo King RMN II
01-02-2015, 08:54 PM #1
Thermo King RMN II
I have an old railway refrigerated container with a Thermo King RMN II on it I am looking for a workshop manual for this if any one can help that would be great, it has a Therm Guard V controller.
The main issue I am having is that it seems to be stuck in sort of a limp home mode the fridge wont go any colder than zero degrees Celsius even though it is set on -20. when I have it running on the diesel engine the engine does not get above an idle??
Any thoughts or ideas would be great
I have attached a photo of the unit for you to see
Simon
01-02-2015, 09:27 PM #2
Re: Thermo King RMN II
What's the gas pressures when it's running it's not something simple like the speed solenoid seized
02-02-2015, 01:25 AM #3
Am thinking its electrical as it was working fine till I had an electrician come and work on it the other day, but will check gas pressures when its running and will let you know
02-02-2015, 08:15 PM #4
When it's on mains electric how does it perform? and did it perform better before the electrician cursed it.
