Results 1 to 8 of 8
25-01-2015, 03:36 PM #1
Question to you experts out there...
Hi, my 7 meter easycold branded commercial fridge started playing around and i called in an engineer to fix it. Instead of 2° C it was on 10° C. The engineer told me that the "gas" had finished in the fridge and that it would cost me £500 to fill it up and get it running properly again. I couldn't afford the meat/dairy/fruit/veg produce to go bad so i went ahead with it. Everything works well now and i would just like to know if that price sounds right to you guys? Apparently the gas is £400 on its own. This is the gas he used...
Thanks for your replies
Sonny
25-01-2015, 04:06 PM #2
Re: Question to you experts out there...
r404a- http://www.refrigerantgases.co.uk/sh...egory&cat_id=2
http://www.orionairsales.co.uk/r404a...tion-852-p.asp
gas price is under £!50 quid, the question is , if the gas has gone, did he find the leak? and is it repaired or did he just squirt it in and leggit?
if you say a typical hourly rate mon-fri is £40 per hour- more down south, did he spend a few hrs?
if he's repaired the leak properly then he would have needed nitrogen- £35 a bottle and ideally replace the liq line drier- approx 20 quid
25-01-2015, 04:16 PM #3
He didn't mention a leak he just said that the gas had finished and it took him an hour to finish the job, he didn't relace anything. Did I just get mugged off?
Oh and I'm in Essex
25-01-2015, 04:45 PM #4
he's topped up a system, having a bottle of 404a upright, with no dip tube on it ( only 1 port, labelled vapour) he's not charged it in liquid form, (bottle must be upside down to charge)
if the gas has leaked out it will leak out again, breach of f gas regs
id say he's had ur keks down and spanked ya- northern term
25-01-2015, 08:16 PM #5
Thanks for your reply pal, lesson learnt I guess.
26-01-2015, 07:37 PM #6
report him
26-01-2015, 08:15 PM #7
26-01-2015, 08:29 PM #8
For that price I would fly over twice a week...... and bring my own refrigerant.
